Hier mal ein wenig beschreibung aus dem Netz. (gmpartsdirect.com)
Open Chamber Cylinder Head (Cast Iron) 1968-90
This is Chevrolet's best cast iron cylinder head for high-performance big-block V8s. It offers exceptional power at an economical price. This casting has 118cc open combustion chambers that reduce shrouding at high valve lift and improve engine airflow. The seats are ground for large 2.19" diameter intake valves and 1.88" exhausts. This high-performance head has rectangular intake ports and square exhaust ports. It is machined for 7/16" screw-in studs and guideplates (not supplied). Small Image
Technical Notes: This head was installed on LS-6 engine and LS-7 engine. It can be used with both closed and open chamber pistons to produce various compression ratios. Casting number 14096188 or 6272990. Cannot be used on Gen V engines because of upper water hole alignment. Open Chamber Desig
Preis 700,- für beide
Biete: Zylinderköpfe High-Perf - 502 - Gen. IV
- LuckyTilo
- image3.jpeg (122.01 KiB) 3662 mal betrachtet
- image2.jpeg (171.05 KiB) 3662 mal betrachtet
- image1.jpeg (174.03 KiB) 3662 mal betrachtet
- Obergefreiter
Re: Biete: Zylinderköpfe High-Perf - 502 - Gen. IV
Hi!
Gibt's die Köpfe noch?
- LuckyTilo
sind gestern weg gegangen...
Sorry
Sorry
