biete hier diverse Teile aus mehreren Motorenumbauten an. Ich schicke euch gern Detailsfotos von jedem Teil. Die Teile sind alle in einem guten bis sehr guten Zustand, manche sind NEU. Die Preise sind alle VB und Packet Deals sind bevorzugt... Ich habe noch diverse weitere Teile übrig! Einfach mal nachragen...
Nr. Quantity Parts / Description Price
1 4 4" Gibson clamp on Mufflers 2015, used 5 Times, like brand new 1.000,00 €
2 4 4" Switchable Air Mufflers, looks very good, works good, including all switches, Actuators etc. 800,00 €
3 1 Holley Dominator, Chrom Series, black cotaed, works perfectly, including some Bleeds for 600,00 €
adjustments
4 2 Camshafts, 2012, barel used, works perfectly, removed only for EFI Conversion, same as Nr. 24 440,00 €
5 2 Polished Stainless Steel dual Fuel Rails for Carburators /6 76,00 €
6 2 CMI Distributor Jumper Hose 3/4" Complete Kit 300ea
7 1 Mercruiser HP Performance Oil Mounting with braket 300,00 €
8 8 Connectin Rods, YPM 275, 6.635 Crower 200 ea set
9 4 Tall Valve Cover Breather, including Bolts and Gaskets 50,00 €
10 1 Steering Pump 280,00 €
11 1 Steering Pulley 30,00 €
12 2 Timing Covers 110,00€ ea.
13 1 Distributor Coil Over, Complete incl. Spings, Caps etc. like new 150,00 €
14 16 Stainless Steel Intake Valves 18 € ea.
15 2 Cometic MLS Headgaskets for Gen IV 130,00 €
16 4 Extreme Duty Exhaust gaskets 3 brand new, 1 used 35,00 €
17 1 MCGard Propeller Lock 40,00 €
18 2 Bravo One Flo-Tourque Kit II, one complete incl. MCGard Propeller Lock, one missing 85,00 €
Drive Sleeve
19 10 Bolts 8,00 €
20 2 Kiekhaefer Trim Pump SAE J1171, very good, with Brakets, with solenoid, Complete 300,00 ea
21 2 MSD Bushing and Spring Set Part 8464 35,00 €
22 2 2 Sets of Heavy Duty Cylinder Head Studs 180,00 €
23 2 Stainless Steel Performance Valves 1.950 145/410 120,00 ea
24 2 Bullet Racing Camshaft 220,00 €
25 4 4" Hose Rubbers connecting exhaust systems 15,00 €
26 1 Latham Marine Tie Bar 190,00 €
27 1 Donzi Steering Wheel 50,00 €
28 1 1 complete set of Crane Cams 8.5mm Pure Silicon 25 Ohm Firewire 30,00 €
29 1 Driveline Centr Parts Kit CPL15N 1 S, NEW 50,00 €
30
31 1 Sea Water Impeller Pump, 47 59362Q01 20,00 €
32 1 Mallory Tube Exhaust 20,00 €
33 2 K-Planes Trim Tabs 350,00 €
34 1 MSD Ignition MSD 6M-2, MSD Ignition Soft Touch Rev Limiter - all very good codition 190,00 €
35 1 Mercruiser Shift Bracket for BBC Bravo 40,00 €
36
37 4 Dart Iron Eagle 345ccm, Heads 1.500,00 €
38 1 Brodix Intake, Ported 300,00 €
39 3 Quicksilver Cross Bearing Assembly, 75832T 1, new 30 ea
40 1 Quicksilver Bearing Kit Gimble, 30-879194A01, new 55,00 €
41 1 Impeller Kit, New 100,00 €
42 2 Powder Coated Crankshaft Pulleys 30,00 €
43 1 Almost new Raw Water Sea Water Pump with bracket and Pulley 480,00€ ea
44 1 MSD Blaster 2 30,00 €
45 1 Raw Water Pump case, Impeller Kit 75,00 €
46 4 Pulleys, black coated 60,00 €
Ich habe für jede Nr. Detailsfotos, einfach PM oder Email schicken... Ihr erreicht mich unter 01775983212.
Beste Grüße an alle!!
Biete: Diverse Teile, Pumps, Pulleys, Heads,
- Obergefreiter
Re: Biete: Diverse Teile, Pumps, Pulleys, Heads,
What sizes clamp on is the Gibson mufflers? 4" or 4 1/2"
