Newest design in drive showers
- No more square box drive showers
- The top cover is polished, smooth and sleek, no exposed bolts
- The all new hydro designed water pickup develops up to 30 lbs. of water pressure.
- uses a full flow -10 AN (1/2" I.D.) water line, not -8 AN (3/8" I.D.) like competition
- more consistent flow and pressure independent trim angle
- Lower your oil temp to 60°
* Easy mounting
* No maintenance required
* High polished VA 316 SS
* Complete kit including all hardware
Price: € 175,00
Will fit Bravo 1, Bravo 1 X, Bravo XR en Bravo II
Also available for Bravo 3 € 185,00
[/b]
BIETE LUXE Merc Antriebe Dusche LUXE / Drive Shower
- NORDIC POWERBOATS EUROPE
- spray22.jpg (48.41 KiB) 5091 mal betrachtet
- 456137-1-L.jpg (55.37 KiB) 5091 mal betrachtet
- bravo deluxe drive shower.jpg (58.26 KiB) 5091 mal betrachtet
bei mir
Test results are (finally) in... They not only looks awesome, they will outperform every other brand of drive shower
I quote the manufacturer:
We have performed hours of seat time testing on every type of pickup out there, some are better than others, but the bottom line is most pickups grab water directly above the prop where there is alot of turbulance.
There's alot of variables depending on the X-dimension and the type of hull when talking about how well a drive shower works. Our pickup is specifically engineered as a water pickup. Not just an angle cut tube trying to scoop up water. We position the pickup behind the prop for a cleaner flow of water. This also prevents prop cavitation which can be caused by a pickup directly above the prop.
Our pickup outperformed every pickup style that is currently on the market, 35 lbs of water psi when the drive is trimmed in and with the drive in full up trim at wide open throttle, it drops to 20 psi, which is alot of water. Our showers are the only shower to feature a 1/2" I.D. -10AN line compared to everyone else's 3/8" I.D. -8AN line.
- driveshower2.jpg (12.1 KiB) 4937 mal betrachtet
- driveshower3.jpg (16.18 KiB) 4937 mal betrachtet
- driveshower1.jpg (28 KiB) 4937 mal betrachtet
Here's some more in action shots - Note the actual pressurized shower cap, not a line blasting water all over the transom of the boat, or hosing down the gimbel. This shower actually works. It fits all Mercruiser Bravo drives, even the new finned style caps, standard and ITS.
The volume of water flowing through the Dana pickup at full up trim is shown in the picture of the shower spraying straight down. The gauge below shows 33 lbs of water psi, this is with the drive almost to half trim, with the drive tucked all the way in our pickup developed 40 lbs of water psi.
- driveshower6-LR.jpg (89.18 KiB) 4936 mal betrachtet
- driveshower5-LR.jpg (86.74 KiB) 4936 mal betrachtet
- driveshower4-LR.jpg (89.37 KiB) 4936 mal betrachtet
New arrival on these "SUPER" deluxe drive showers
Best part; they have been upgraded and are working better then ever before and better/ nicer looks (high & fully polished 316 SS), redesigned water pick-up (see pictures / details). No way they can be compared with other existing drive showers
Negative part; more expensive
On stock ready for delivery right now
applications for Bravo 1 and XR's or Bravo 3
- dana drive shower LR c.jpg (87.99 KiB) 4797 mal betrachtet
- dana drive shower LR b.jpg (88.11 KiB) 4797 mal betrachtet
- dana drive shower LR a.jpg (84.49 KiB) 4797 mal betrachtet
Complete set including SS mounting hardware and instructions
- dana drive shower LR f.jpg (82.59 KiB) 4796 mal betrachtet
- dana drive shower LR e.jpg (84.29 KiB) 4796 mal betrachtet
- dana drive shower LR d.jpg (76.84 KiB) 4796 mal betrachtet
